Does anyone know if the high density extruded foam insulation board (blueboard) can be used in direct contact with pipes at 180*F? I have an idea to insulate 1" PEX in a homemade blueboard "sandwich." The pipe would be completely encased in the blueboard. There would be direct contact between the entire circumference of the pipe and the blueboard. The run would be approx. 100ft. Will the blueboard survive?
