Blower rattles .
Dmitry
1,219
CT
One of my blowers rattles on certain speeds. Goes away after playing with speed. Is there fix I can try before replacing it? I've inspected and cleaned it. No visible damage.
It could be an off-balance fan cage. Make sure its blades are all clean. Also check to see if something else is the actual rattle caused by the vibration of the blower.
Pry up on each corner of stove with lift bar see if noise goes away. Maybe it’s not level
Buy a small package of magnets and experiment with a couple to see if you can balance things out
welcome to the club, all the blowers rattle on my stoves, drives me nuts so i seldom turn them on anymore.
We’ve replaced 2 sets of Lopi flush blowers recently. Both had bearings seizing on one side. Typically they are very quiet, and sit in there very tight, there’s not much adjusting that you can do. Make sure they are bolted down tight. Could pull them out to Clean them, and check the bearings.
Make sure you've cleaned it thoroughly. Mine gets pulled off from time to time and blown out with compressed air. Any remaining stuff on the fan blades gets wiped off with q tips.
