I can't recall ever seeing a discussion or suggetions on this, so I feel that some may find it useful. I thought about posting it on the tools forum....but that would be flattery to call what I use to huff my fire up a "tool."
Some like a bellows, and I've use them plenty. Some will pay top dollar for a copper and brass blow pipe with a brass mouthpiece and engravings....if you have one of those, I'm sure it works fine and looks great standing next to your stove. Me, I'm cheap, and functional, and if I can make it myself, I will. Here's what I use:
First, get a length of 1/2" copper pipe. The length of it is a personal choice. You want it long enough that you won't have to kneel down to use it. Mine is about a yard long. Find a piece of soft wood and stand the pipe up on it. With a broad faced hammer, wail on the other end a few times, straight down, until the cut edge you are hitting starts to compress and roll. This will be your mouthpiece end. Next, lay the pipe on its side and squash the end almost closed with a few hammer blows. You want to leave just a slit so that you'll build back pressure and really get some velocity when you blow on it. If you go too far, just use a flat blade screwdriver to open it back up.
In the mornings, when I've just got a few embers, I rake them into a little pyramid, top it with a split and huff it to life. Aim for the lowest point on the embers. Sometimes it will blow smoke and ash back out the door, so keep the door closed on it as far as you can. Really though, that is minimal. A few blasts and you will have ignition. Don't inhale. If you are kneeling, don't stand up too quickly.
