We were called out by an HOA, to a condo complex consisting of 21 individually condos, set up just like apartment complexes (4-8 units per building) to do inspections and give estimates for new chase covers. After talking with the President of the HOA and doing a level 1 inspection on each unit, our findings were: (1) Recently had a chimney fire in one unit due to separated flue pipe in the attic. (2) They had recently had siding replaced during the process the existing chase covers were removed, then reinstalled by the people replacing the siding (3) Our findings were several units had the top section of flue pipe not connected (assuming that when the chase covers were reinstalled, they were simply screwed back on and no effort to ensure the flues were connected properly was taken) Some units had signs of heat damage in the attic by showing black or charred wood and insulation around top of chase (4) Original units were installed almost 40 years ago with no proof of routine inspections or maintenance during their lifetime
Our suggestion to the HOA was to discontinue use of all fireplaces as the flue pipes had been compromised by being pulled apart and after 40 years there is no way to ensure they would be 100% safe even if they were all reconnected as best as possible.
We offered a bulk replacement estimate to replace all 21 units, which was frowned upon by the HOA. Mind you these are individually owned units the HOA is acting as a third party between us (chimney repair company) and the homeowners. Once the bulk replacement was turned down they requested I send each individual unit a copy of our findings for each unit and options to correct the problem. We offered 3 options. (1) Replace entire unit and flue pipe with new ones (2) Remove existing wood burning stove and flue pipe and install an electric unit (aesthetic purposes mostly not heating) (3) Remove entire unit and hearth leaving chase above roof line with closed chase covers.
HOA requests on behalf of the homeowners that for those that don't want a replacement, that we simply install a chase cover with no hole and screw a metal piece over flue opening inside firebox blocking the flue.
We are very uncomfortable with this option as it just seems dangerous.
Advice on how to handle this situation, any laws or codes we should be mindful of? Liability on our part should someone try to use the fireplace with a blocked flue? We are in Texas.
