Hi all,
First time poster here. I've purchased a house and currently doing a complete tear down and rebuild of the interior and exterior. There is an existing cinder block chimney that has been lined with a stainless steel insert. I plan on using it this winter with the wood stove in the basement. During the tear-down, we found out that there used to be a 2nd stove on the 1st floor connected to the same chimney, before it was lined with stainless. The previous owner only put some fireproof mineral wool in the hole before putting drywall over....I'd like to close off this hole in the proper way with brick and mortar. Here's some pictures of what I need to deal with:
With that being said, I've got a few questions:
1. Should I cut back some of the bricks to create a space for insulation behind the drywall? Currently the bricks (in not so good shape) are flush with the interior of the studs.
2. Can I use regular bricks or they need to be some specific clay type or something?
3. Should I use type N or type S mortar? I've seen both being recommended...
