Does anybody happen to have any ideas on how I should go about making a block off plate for this set up? As you can see, the installer had to chip away a lot of brick to get the liner in there. Where the brick is cut is very uneven. My current plan is to make a three piece plate, one for the middle with a hole for the liner to push back into the uneven slot and then two for the sides which will overlap the middle. I'm still worried about being able to fully seal it, even with a lot of caulk. I've cut up a bunch of cardboard and the best i can get still has some pretty good gaps. Anyone have any other secrets or ideas? You all seemed to have such clean finished jobs, i can't imagine i'm the only one with such uneven brick.
![Block off plate with uneven brick Block off plate with uneven brick](https://www.hearth.com/talk/data/attachments/255/255248-c31f6d4075467926aab6f2d758b1839c.jpg)
![Block off plate with uneven brick Block off plate with uneven brick](https://www.hearth.com/talk/data/attachments/255/255247-9dd2eb1f79b498f4598a9a37040eac15.jpg)
