is it better to use existing damper or make a sheet metal will i keep more heat using my existing damper?
once my stove is in i never plan on removing it
iceman said:is it better to use existing damper or make a sheet metal will i keep more heat using my existing damper?
Most suggest installing above the lintel because most lintels are made out of 1/4" or larger angle iron. Not easy to just tap some screws in. As long as you cover the area and get a tight fit around, your fine where you want to put it. And looks like it will make it easier for you. Easier is better .udris said:Is there any advantage to installing the block off plate just above the lintel? My firebox has a perfect little notch all around exactly flush with the top. I could slide 3 edges of the block off plate into this notch and screw the front edge up into the lintel. I noticed that the block off plate designs on this site specify installing it a couple of inches higher. Is there a specific reason?
Hogwildz said:Most suggest installing above the lintel because most lintels are made out of 1/4" or larger angle iron. Not easy to just tap some screws in. As long as you cover the area and get a tight fit around, your fine where you want to put it. And looks like it will make it easier for you. Easier is better .udris said:Is there any advantage to installing the block off plate just above the lintel? My firebox has a perfect little notch all around exactly flush with the top. I could slide 3 edges of the block off plate into this notch and screw the front edge up into the lintel. I noticed that the block off plate designs on this site specify installing it a couple of inches higher. Is there a specific reason?
iceman said:can i just cut my damper plate to fit the liner, put insulation around any gaps between the liner damper and then seal all the way around damper with sealant or do i really need to make a plate?
iceman said:Hogwildz said:Most suggest installing above the lintel because most lintels are made out of 1/4" or larger angle iron. Not easy to just tap some screws in. As long as you cover the area and get a tight fit around, your fine where you want to put it. And looks like it will make it easier for you. Easier is better .udris said:Is there any advantage to installing the block off plate just above the lintel? My firebox has a perfect little notch all around exactly flush with the top. I could slide 3 edges of the block off plate into this notch and screw the front edge up into the lintel. I noticed that the block off plate designs on this site specify installing it a couple of inches higher. Is there a specific reason?
Hog I saw pictures of you on an install... Feel like driving up to mass??...lol
