So I got somewhat lackluster heat out of the stove this past winter (first winter). Wood was under 20% albeit just barely. Unfortunately, I wasn't there when they installed the stove. I had been told that the blockoff plate was part of the installation process. So we pulled the stove out a couple weeks ago to redo the surround, and so I figured this would be great opportunity to insulate behind the stove (thanks for inspiration Mellow).
Turns out they had just stuffed a little pink fiberglass insulation up around the flue area (maybe half a batt). So I yanked all of that out and shoved multiple batts of rockwool up there and zipped in comfort board around the interior. I even stuffed some more rockwool behind the comfortboard in the back.
Will a metal blockoff plate make a meaningful difference at this point? I should be able to put one in over the top piece of comfortboard, but I'm sitting here scratching my head as to if it is really worth the hassle. The back of the fireplace isn't uniform to seat it against. So I'm not sure if I can really get it sealed on the back edge.
