I sure hope the 2020 regs don’t damage performance of the bk models.
With the larger clearances I wonder if it is a bit more radiant than the older insert? If so that could be benefit for people looking for heat during power outages as long as their installation meets the clearance requirements.I sure hope the 2020 regs don’t damage performance of the bk models.
So, the PI1010A had a low Btu range of around 12,254. The new PI29 has low burn range of around 12, 279.
That is the "real world" listing. Not exactly sure what that means. The EPA test shows a low burn rate of 10,633 BTU/hr.The PI1010A manual specifies a low burn of 6200 BTU. Is that a typo or something?
The new model burns just as low. As mentioned previously, go look at the EPA site. You will see the ranges have changed very slightly, both up and down based upon combustion technology employed.Hmm, says so right on the page I screenshotted.
In my defense, the first thing that page says after the title is "Minimum heat output 6200 BTU", without any qualifiers to indicate that there might be a second 'minimum' value.
The new PI book doesn't seem to mention "real world" BTU values. Hopefully it turns down just as far; I am guessing it probably does.
If they can do the testing that way, maybe everyone doesn't have to cut the lowest ranges out of their stoves- they just need a manual that tells the operator not to use 'em.
I didn't mean to put you on the spot. Look down at the bottom of that same page where more info on output is provided.Hmm, says so right on the page I screenshotted.
Fingers crossed that the wide range of available outputs from all bk stoves remains in place after proving compliance with the new regulations. Even better if the stoves have lower emissions. I don’t think anyone would complain about lower emissions. Oh and efficiency, please don’t give up efficiency either!
