Well folks, I had a suspicion I had a problem - ever since I got my new
BK Princess Ultra (freestanding) last autumn, and it looks like I was right.
I finally removed the cover on the thermostat. I tried to do it awhile
back, and after I removed the two square-drive screws, it was still
really stuck in the back (up against the stove) and I was afraid to beat
on it too hard, given the dire warnings against removing said cover (on
the sticker). But the tech guy at BK said it was fine to remove it, once
he realized I wasn't an idiot. And with the stove hot, it came off
quite easily. Removing the cover does not affect the airflow, although
of course you want to replace it when done trouble-shooting. One
thing he said (IMPORTANT): turn the control knob down so that the
flapper is close to fully-closed before re-installing the cover, lest the
edge of the butterfly flapper wedge against the cover.
So here is what I found. I set the thermostat control at about 2 and
left it there throughout this experiment. I measured the width of
the valve opening - between edge of flapper and the opening (where
is unimportant, as long as you're consistent). With the stove almost
completely cold, it was about 1-1/8" open. I built a good fire and after
an hour or so the opening was close to 2". I let the fire burn down
overnight and by morning the stove was pretty cold and the opening
was down to 1" or so. Clearly this is wrong - for a given control knob
setting, the valve should close as the stove heats up and open as it cools
down.
I confirmed this with BK and the dealer is sending me a new thermostat
assembly with prepaid return label for the old one. It appears to be held
in place by two screws and some silicon sealant (presumably some high
temperature variety, hopefully available locally). So stay tuned ...
The kicker is ... even with this gross malfunction, this is still, by far, the
best woodstove I've ever had, easily keeping a fire going for 12 hours !
down.
