As per request I'm starting this thread hoping it may help some of you other Blaze King burners that are having smoking issues or sluggish restarts. As my burning season began to wind down I took the cover off to check the operation of the t-stat and when I was done I tried to install the cover back on and noticed it didn't line up with the mounting screw holes if the butterfly t-stat was open a ways. The cover was resting on top of the butterfly.
After awhile of tinkering I noticed that the holes would only line up if the stat was below a setting of about 2.5, this leaves a lot of air leftover in reserve since the numbers go up to 3.5. I ran the stove for a few days with the cover off and noticed a big difference in performance. No more smokey reloads, faster take offs during reloads and cold starts. It also helps to have that extra air to burn down coals when needed.
I was thinking of just leaving the cover off but I have an OAK hooked up and figured it would be pulling room air with it off so I ended up modifing the cover. All I did was take some tin snips and cut up from the bottom to the mounting holes and made it adjustable so I could slide the cover up and the butterfly can go to it's max setting.
View attachment 102711 View attachment 102711 View attachment 102713![Blaze King Princess T-Stat Cover Mod Blaze King Princess T-Stat Cover Mod](https://www.hearth.com/talk/data/attachments/102/102715-0248978505075854a5fe48c20ca147b2.jpg)
