I'm the new kid on the block and this is my first post. We purchased a Blaze King Chinook 20.2 late in the summer. We use it to heat a bathroom and a couple of bedrooms. Overall, we are very happy with the stove. We get great burn times. My only complaint has been that I have to fiddle with the fan once in a while particularly if the outside temperature changes drastically during the night. And I find that if I turn up the fan, I can pull enough heat out of the stove that I have to adjust the thermostat to keep the stove in the active range.
As a guy that is profoundly lazy, I put together a Raspberry Pi with a Max31856 thermocouple board, a K type thermocouple, a MCP9808 for ambiant temp, and a PCA9685 servo controller, 2 RC servos along with some software to make a Blaze King stove controller. I am using a 7" touch screen for a human interface.
I discovered early on that the flue temperatures fluctuate wildly as the Blaze King adjusts the airflow to maintain a constant or nearly constant burn rate. Instead, I sample the stove temp every 5 minutes to compute the rate that the stove temp is changing. If the stove temperature is decaying to the point where the combuster is in danger of falling out of the active zone, the thermostat is turned up slightly. Currently, the thermostat is only ajusted as needed but never more than once in a 15 minute period. Many times, the thermostat requires no adjustment for hours. The room temperature is maintained at the target temperature by modulating the fan speed. Only if the room temperature starts to decay relative to the target temperature and the fan speed is already at 100 percent, does the system intentionally turn up the thermostat.
I have some questions.
1. Has anyone else automated their Blaze King?
2. Are their any issues with running the stove near the bottom of the active zone during fall and spring?
3. Am I correct in assuming that it's more efficent to run a lower thermostat setting with a high fan speed than a low fan speed with a higher thermostat setting to maintain room temperature?
4. Does anyone know if all Blaze Kings have similar characteristics with respect to control operation. Our Chinook becomes very sensitive to changes in the thermostat as the thermostat is turned down. Is that true of other models?
5. Does anyone know if what the expected latency between thermostat adjustment and the reaction of the stove to the change?
Thanks,
Bruce
![screen.png screen.png](https://www.hearth.com/talk/data/attachments/289/289342-db6ffcebad686a69d4b816377332cbf2.jpg)
Thanks,
Bruce
