First, I did search the forums and I'm sure the answer is there but am not finding what I'm looking for.
I've been lurking here for years. Previously, I owned a Quadrafire and loved the heat output. That thing was like a blast furnace. I recently built a new home. It's a 3 story ~4000 sqft. I bought a Blaze King Ultra in hopes to at least supplement heat. I know 4k is pushing its boundaries. So I installed it on the main level. The main great room is a large open area with a 2 story wall of windows and open kitchen adjacent. The pipe is ~14' straight to 3 ft of 45* then straight up through the roof - so I expect my draft is sufficient. Also, the placement of the stove isn't the greatest. It's near the outside wall of windows.
I had hoped that the stove would at least heat the main and upstairs. Actually, I had hopes of running the central fan to push some heat to basement too. I've gotten past the break in and am trying to push it with this stove to get some real heat output. I'm burning lodgepole and fir mix which normally translates to some high temps. Maybe not the driest (don't know the numbers) but drier than I had in my quadrafire that would run us out of the house. I can load this up, get it roaring, flip the bypass and temps will get up to about 5-600. I then slowly back the tstat down to ~mid. There the stove top sites about 500 +- and holds. The loads last a long time which is great.
However, the heat coming of the stove is weak, at best. I'm talking heat volume. It just seems to be lacking. I read forum after forum about these things running you out of the house. This doesn't even make it hot in our great room let alone the rest of the house. IF I'm standing next to it, i can feel some heat but nothing like my quad. For example, as I type this, I'm ~2ft from the front of the stove. Stove top temp is 500 and I barely feel any heat coming off of it and my heat pump is running to keep the temp at 65 (tstat is in the great room). All things aside, even if it's not sufficient to heat my house plan, I would at least expect to be feeling the blast from 2 feet away...
1. I know that I could be running drier wood. I'm sure that's the default answer. However, it's as good or better than what I ran in my quad. Why would that make such a difference? It's standing dead that was cut this spring for reference (mostly pine).
2. I'd like to crank this thing up to max on the tstat. I'm not sure how hot I can run it. Manual just says, 'don't overfire' but that's not helpful. How hot can I push this thing? Can I run it hotter if I run the fan (I'm not a fan of the fan - I like a quiet house)? Is running the fan necessary to push the temps on this?
3. Maybe the way I'm loading the wood? Pics I saw from forums showed people loading it to the hilt. I've tried to do the same. There's a good bed of coals, 1st layer NS, 2nd layer EW and so on. ~6-8" splits.
4. Maybe some advice on how to get it going? I'm new to running a cat. I'm willing to admit I'm doing it wrong. I open the bypass until I see active flames and the cat is in active zone, then close bypass and let er rip to bring temps up for a while before slowly backing the stat down.
5. OAK. It's a newer home and insulation was awesome. Spray foam 1", then blown cellulose, 6" walls and every hole sealed. Is it possible that the stove is choked? I did ask for an OAK but the installer came while I was gone and didn't do it. I'm willing to add one myself but am reluctant to move this thing and cut a hole in my hearth...
