Getting ready for first fire of the season as temperatures are getting down into the 30's now. I had a leak this summer, well, not quite a leak, but an inadvertent discharge from the closed system due to a valve being left open on an open line. Anyway, I measured the air pressure at the schrader valve on the top of my Well-X-Trol Model WX-350 bladder type expansion tank and it read only 3.0 psig. My circulator at the boiler was running early this morning when I went to the barn due to the low temperature and a thermal snap switch I installed last year. It did not sound good, sounded like it was cavitating. After shutting off the circulator, I opened a bleed on top of the boiler and it did not gush out under pressure as it has in the past. Last year when I measured the pressure at the expansion tank it was 7.5 psig with the system cold.
I inherited this system a few years ago, and have only been able to improve and operate it due to the valuable shared knowledge on this site. The elevation of the expansion tank is about 2 feet above the top of the 1000 gallon storage tank.. The expansion tank is on the suction/inlet side of the boiler circulator pump P1. The tank is 119 gallong total with approximately 46 gallons acceptance. I was worried about it being designed for wells due to the high temperatures inherent with the boiler, but it is rated for 200F, which it should not see on the inlet side to the boiler. I have not had any issues with my P&T valves opening during the last few seasons, so it must have adequate volume for the expansion of the 1100 gallons or so in my system.
I have opened the fill valve at my storage tank and refilled the system. The pressure regulator on the fill line is set at 12 psig. My relief valves (one at the boiler and one at the storage tank are set at 25 psig. My question is what should I set the air side pressure to in the expansion tank? Below is a schematic of my system.
Thanks for any and all help!
Kevin
Kevin
