Tonight I went out to the farm where my wood is stored and dropped off a botttle of wine to the owners of the farm as a thanks for the wood and storage. On my way back wife calls and said it is black behind the stove. I said leave it alone I will be there in a minute or two. As soon as I walk in the house I could smell it. The creosote/water ran down the chimney pipe and onto the floor. Man does that ever stink/smell. I took the stove out of down draft mode and let it heat the flue back up and problem gone. This has been a reoccuring problem if I let the flue temp get to cool then this always seems to happen as the fire picks back up and reheats the flue I guess.
Flue temp 18" above stove in downdraft mode will run around 2-250 with stove top temp at 450-500. IF it shuts down a bit then this happens with the water thing. If the flue temp stays up consistant no problems. When burning up updraft mode flue temp runs around 400 and no problems.
Should I just avoid downdraft mode? It has been very damp here and raining/misty the last two days with tems around 34-38F
Does those creosote powders (scoop on the fire during ever load) do any good to help keep the flue clean? Or is that a scam?
8x8 tile chimney outside concrete structure
