Any good pointers to a "black pipe 101" reference? I've done some searching, and found some good threads with info on component choices, thread sealers, and so forth, but haven't found any good pointers on how to figure dimensions, and layout type stuff - i.e. things like:
I want to go from point A to point B w/ my pipe run, how do I figure out what lengths of pipe to use, how much length the fittings will take up, and so forth?
If I have a peice of pipe that's threaded on both ends, and has an end to end measurement of X inches, how much length will it add to my run when I put it into fittings?
Or the reverse, if I have two fittings that are X inches apart, how do I figure out the length of pipe that I need to connect them?
How much room do I need to allow for thermal expansion, especially if going around a corner or something like that?
Are there "rules" about where one MUST put unions, or is it just a question of convenience?
How about any other required, but not immediately obvious techniques (like the crud trap legs on gas feeds)?
How much can you "flex" the pipes to get everything to line up? (or how far "off" can you get away with?)
Are there rules about when you can and can't put your own threads on a pipe, as opposed to using 'factory' threaded nipples and lengths?
I've done a bit of pipe work here and there, but it has generally been "guess and golly" as to getting stuff to line up and fit together properly.... OTOH, when I've watched plumbers doing it, they seem to take a couple measurements, go grab some pipe and fittings, and it all fits together just right - I'm sure they must have some formulas or charts they use to figure out what parts to use, is there some place where us "mere mortals" can find them?
If someone can either post a nice "piping 101" article, or a pointer to a good reference, it would probably be worth adding to the "useful resources" sticky...
Gooserider
Gooserider
