I have black gooey liquid running down my fireplace brick and last year ive seen it actually run out of the wood heater door. This year will make 8 yrs that ive been using a wood heater. I originally had the larger of the two boxwood stoves that I bought brand new from tracker supply. Last year we bought this larger stove and this is when all of our problems started. Our chimney is closed off with a thick piece of metal about 3 ft above the stove with a hole cut in it to run the pipe out. The chimney is brick all the way to the top. With the boxwood stove we had the stove pipe going about half way up the chimney never had any problems with the draft. If the heater door was open it would actually pull my cigar smoke that way and up the chimney. So when we installed this larger heater last year we just connected it to the same pipe (had to add an elbow) expecting the same results. That wasn't what we got at all ! Every time we would open the door (damper completely open it would smoke up the house and it didn't make that roaring train noise like the boxwood stove. This is when the oozing started. This year we've took the pipe all the way to the top which has given us excellent draft but we still have the oozing. Its still running down the brick as you can see in the picture and it runs really bad down the inside and outside of the pipe. Oh I almost forgot, after we ran the pipe all the way up we tried it for about a week and the only change was the better draft so he capped the top of the chimney off closing it completely with the pipe coming out thru the center. Can anyone help me ? Why did this start happening with this different heater ? PLEASE COULD SOMEONE TELL ME HOW TO FIX IT ?!?! I greatly appreciate any help or suggestions PS. I read the article "Creosote from Wood Burning - Causes and Solutions" and in that article it says to prevent buildup you need to burn up the gases that form creosote. "Burn the smoke and you burn the gases. No gases, no creosote." I don't understand what this means. How do I burn the smoke and gases ?
![Black gooey liquid oozing down my fireplace brick Black gooey liquid oozing down my fireplace brick](https://www.hearth.com/talk/data/attachments/145/145297-8b699690323c74a2656a4a8662259ceb.jpg)
