Finally burned my small amount of scrounged black cherry and I'm loving those big square coals it makes.
Yessir. I can hold 350 on the stove top when burning down coals to make room in the box, but when it's super-cold out I need fresh smoke to get that combustor cranking and the stove up around 450 or 500. I've still got some air leaks to seal up in this place, so that should help me hold room temp longer when I'm burning coals.Because they take up a lot of space?
Coals are great if you're grilling meat but are the bane of my existence when I'm trying to get a lot of heat out of a small fire box.![]()
The Keystone, when I burn 'em down with the bypass closed.Ya talking about a CAT stove?
Ralphie, measuring the temperature of inserts is a challenge for sure. You probably do reach those temperatures but just are not aware of it.
That's what I've been thinking, just no way to get an accurate reading on an insert.
I've got a surface meter on the front of the Buck, about where I figure the stove top intersects the front. It generally reads about 350-400. I've seen 500 when the cat is really cranking.Wow, I can't get my stove top that high without frying the CAT! Or maybe I am getting it that hot and don't know it.
