Black bubbling liquid oozing out of bottom side seam during break in fire on jotul oslo. Is this common?
stoveguy13 said:Have you checked the air controll area for excess furnace cement build up? it tends to fill up around the bolt and can make it stick there have been some firelights that were sticky i have only seen one oslo with the same problem not related to furnace cement but the are working an a new air lever to stop it completly
Had that puppy up to 700 degrees this morning, the shut the air off, and I can tell you it cranks the heat.
