First off thanks to everyone here, all your comments guided me to buy a BK King Parlor last year, and the Sirocco 25 insert this year for my unused fireplace. Had a block off plate installed with it since most here seem to recommend.
My King burns like a dream at or above the maximum advertised limits, very happy with it. Not the case with the Sirocco insert. Everytime I get about 8 hours having it pegged fairly low on the test at dial, a little above 3 o'clock (it closes at 3 o'clock position).
This Sirocco stove had some problems to begin with, defective catalyst thermometer and a bolt popped off the flame sheild, BK sent a new catalyst thermometer and bolts, and I was very happy to get up and running again last month.
My chimney is interior masonry (center of house), insulated ss liner about 17 or 17.5 ft of chimney for the Sirocco 25.
I suspected there is a air leak, and tightened the door after failed dollar bill test (could pull dollar bill right on hand side pretty easy) now its tight. Still, getting more flames than I think I should see turned down low.
I do not know how to diagnose other types of air leaks perhaps @BKVP might have some insight. How do I identify if window gaskets leak or thermostat housing leak?(saw some furnace cement on edges of tstat I presume are to prevent that)
I'm burning mostly oak, tried burning N/S and E/W made no difference since the advertised burn time is 8 hrs. My king makes zero flames turned down low.
Wood moisture meter shows 14% - 17%.
I run the fan to match the thermostat setting. I've bought kiln dried wood to see if I'd suddenly get long burn times and had same results.
Really hope you wizards on here can help point the way to get my Sirocco insert up to its potential.
Thanks!
Thanks!
