Hello, I just discovered this website and it's already been very helpful. I hope my first post isnt too long to get some responses. I also apologize for my lack of terminology.
I am replacing my old Coal/Wood circulator for a new BK Princess 32. Circulator is inefficient and one cast hinge for the ash pan door busted off. After considering my options I am opting for the Princess 32. I wanted the King40 but the 8" pipe size isn't ideal. Princess 32 is still on backorder for 90 days, so I have time to fix issues beforehand.
The circulator was in the house before I arrived. It has a 6" exhaust, and the 6" pipe goes from the circulator to my chimney, however the pipe increases to 8" as it passes through my chimney. There is no additional pipe in my 25' chimney.
I will be adding single wall pipe into my chimney according to code.
My major questions are in regards to the hole in my chimney where the stove pipe enters. It appears a 8.5"x8.5" square was originally cut out of my chimney for the pipe. The people before me put in an 8" pipe fitting and then cemented around the pipe. Well fast forward to now, the cement used to fill the gaps around the chimney pipe is cracking and coming loose. My questions are:
1) What are the proper list of steps to re-cement this area around the chimney pipe?
2) Should I be decreasing the chimney hole fitting from 8" to 6"? (I'm under the impression that BK wants the pipes to be exclusively 6" except for King 40)
I plan to burn wood as my primary heating source, but will have an oil furnace as backup. Any suggestions, questions, or any engagement with me at all will be hugely appreciated. I am still learning & would love to hear what you knowledgeable folks have to say or suggest.
Thanks in advance. I added a pic of my old circulator and a few pics of the chimney pipe hole thats deteriorating. Again, sorry for my lack of knowledge & proper terminology.
![BK install question.. chimney pipe hole BK install question.. chimney pipe hole](https://www.hearth.com/talk/data/attachments/298/298572-f906718f95f38495d82bbff346af4b8d.jpg)
![BK install question.. chimney pipe hole BK install question.. chimney pipe hole](https://www.hearth.com/talk/data/attachments/298/298568-5cd97a7c2155a9dbcfd7eb85abce7c83.jpg)
![BK install question.. chimney pipe hole BK install question.. chimney pipe hole](https://www.hearth.com/talk/data/attachments/298/298569-c2d5c3967ab34333f1a9a7fc17d43d20.jpg)
![BK install question.. chimney pipe hole BK install question.. chimney pipe hole](https://www.hearth.com/talk/data/attachments/298/298570-6c4e8d7aff3efd89c016ed88298c3d7a.jpg)
![BK install question.. chimney pipe hole BK install question.. chimney pipe hole](https://www.hearth.com/talk/data/attachments/298/298571-966a58a1ce7a72eddac81b7dc879e999.jpg)
