Thinking about adding an ashford but before I commit to buy I need to make sure it will work in my house.
Current hearth is 31 1/2” deep from back brick wall to where the front brick trim sticks up a 1/2” higher. Center of chimney is 3’5” from left wall (Sheetrock not side brick wall) and 22 3/4” from center to Sheetrock. I have a hearth extension board currently in front of our current stove to meet requirements. Back brick wall is 5” thick.
Currently the issue is clearances. Particularly Because they say in the brochure that it is 31”deep with the fans. Moving the new stove to the outer edge of the brick gives me about 1/2” to the brick wall so in total 5 1/2” which is shy of the 6”. Someone mentioned in another post that the lip of the ash drawer (which seems to be where the 31” is measured to) to the front legs is 2 3/4”. So if I place the legs at the 31” mark and the drawer lip hangs over the raised brick it gives me 3 1/4” to the brick which gives me about 8 1/4” to the Sheetrock.
Does that sound correct? Or does anyone have the exact measurement from the front of the legs to the lip?
Now the chimney portion.
With the current stove it is a straight shot through the roof but the new one will be back towards the wall by 4 1/8”. Currently the chimney is 17 3/4” from the brick wall. If the above clearances will work the new one will be 13 5/8”. What do I need to get to make this work? Looking at offsets for duravent in 45* would push it back about 5” which again if clearances worked above I have a little wiggle room to move it back the 7/8”.
Only saying duravent because that’s what I have currently have inside. Can the 45s be right off the support box or do you need to space them down first? If so how much? Most likely will need a new telescoping pipe as my flue gauge is not far below the joint. For the new stove from the top of it to the ceiling is a little over 56”.
And finally for now with the added 45s how much does that affect the height of the chimney? Right now I’m at 14ft. Planning on adding an additional 2ft possibly 3.
Sorry for all the questions and probably confusing at that just want to make sure it will work. Here’s a couple pictures of the setup now and a horrible drawing of dimensions that’s a mess.
![BK Ashford 30.1 clearances and chimney adapters. BK Ashford 30.1 clearances and chimney adapters.](https://www.hearth.com/talk/data/attachments/201/201177-b1a845be7ddf5ecaade99898799e8c03.jpg)
![BK Ashford 30.1 clearances and chimney adapters. BK Ashford 30.1 clearances and chimney adapters.](https://www.hearth.com/talk/data/attachments/201/201178-fce0d6712c18e018af99eaf8ceabf24d.jpg)
![BK Ashford 30.1 clearances and chimney adapters. BK Ashford 30.1 clearances and chimney adapters.](https://www.hearth.com/talk/data/attachments/201/201179-d03d42107eb007c7b6bc434e9d32f32b.jpg)
![BK Ashford 30.1 clearances and chimney adapters. BK Ashford 30.1 clearances and chimney adapters.](https://www.hearth.com/talk/data/attachments/201/201180-1a20bffdd5759daad133e56e9650db73.jpg)
Lopi Rockport
Lopi Rockport
