Well I stated up my Pellet Stove for the first time this season like I always do. I did a complete end of season cleaning in the spring. Last week I put the leaf blower to the the exhaust part of the stove from the inside out. I I did not check the pipe outside. Big mistake.
So tonight I decide to startup the pellet stove for its 10th season without fully checking the exhaust pipe. I started smelling slight smoke and the stove sound was slightly different. I figured it was burning off some dust. Well 30 minute later still slight order of smoke a little stronger. Decide to go outside in dark. to check the pipe. There it was a birds nest in the end of the pipe. Shut down stove. Pull what I could see of the birds next out. I notice I have a slight head ache . BIG RED FLAG NOW GOES OFF. Head ache is a symptom of Carbon Monoxide poising.
Tell the wife we got open all the windows and doors and put a fan in the door way to get air flow. to remove any possibility of Carbon Monoxide before we go to bed. BTW Carbon Monoxide takes 5 hour to leave your blood stream with high flow O2. and longer without the O2. It is not something you can be too careful about. Currently the house windows and doors are now closed and propane furnace is warming the house after it went down to 59 degrees.
MAKE SURE YOU CHECK YOUR PIPE FOR BIRDS NESTS![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
