I'm planning on replacing my 2.1 cu ft wood stove (90's vintage) with a secondary burn style stove. It's installed in the basement which is 1600 sq ft unfinished and I use circulating fans to get the heat upstairs (also 1600 sq ft). If the temps are around 25 deg F or above I have no issues keeping the upstairs in the low to mid 70's (basement is in the 80's). Colder than that outside and I have to keep the wood stove fired up with a relatively good burn since it only has a 2-4 hour burn time. I'm looking at the Lopi Liberty (3.65 cu ft firebox) but I'm wondering if it is overkill for my application. Hard to get a Lopi Endeavor with a smaller firebox and I like being able to put longer pieces in stove which I was able to do with my present stove since it is a side load Hearthstone Heritage. Are there any issues with having a large firebox stove and only filling it partially full? I don't need the capacity all the time but when I do I would like the overhead. I'm not familiar with secondary air stove burn requirements and even with my present stove I rarely fill it full of wood. Do larger firebox stoves have different draft requirements? Any input?
