Hello,
I'm new here and have gotten quite a bit of information from this forum so far. Thank you!
We are in the process of buying a new wood stove and it seems like the first branch-point in the decision making process is if it is going to be top or back vented.
We've moved into a new 3000' house, good insulation, lots of cold windows. The power goes out once or twice a winter, usually during big storms. Night time temps are moderate, usually in the teens, rarely dropping to single digits. The house was built in 1976 with a wood fireplace, which was converted over to a decorative gas insert before we bought it, which has been vented through the fireplace and straight out the back of the firebox with a simpson B-vent. The new wood stove is going to sit right in front of where the gas fireplace is now (I'll fill in the void with a heat-absorbing/radiating stone/tile wall). It seems that I should be able to re-sleeve the chimney and run a back-venting stove sitting in front of the hearth. Alternatively, I can just run exposed black stovepipe inside the room, up and out the roof directly above the stove. It'll require a new hole in the roof, but that's okay. I think the height of the rear-vent flue will be fine for most of the stoves I'm looking at in relation to the currently existing fireplace/chimney. The stove is going to sit in the same spot with either option.
The rear vent will require a horizontal run of however many inches are required before making a 90deg turn up the chimney. The top vent will just be a vertical straight shot out the roof (no attic, etc).
Are there advantages/disadvantages to either setup? I can imagine the 90 deg turn could have some impact on the flow of smoke? We do get inversions here. In our previous house, we had an xtrordinaire (sp?) wood insert that I had to warm the flue prior to lighting to start a good draft. I don't know how I'd do that if there was a long horizontal run. Also, would the exposed stove pipe give off its own heat to any meaningful degree? Also, is there less risk of fire with an exposed stove pipe vs. sleeving and old chimney? Are there any other considerations I should be aware of? Does this just come down to aesthetics?
Lastly, just to keep things succinct, we don't want a gas stove or a fireplace insert.
Thanks everyone for your help. I've got more questions about specific stoves, but I'll make a separate post for that.
![[Hearth.com] Big stove for exposed stovepipe vs existing chimney [Hearth.com] Big stove for exposed stovepipe vs existing chimney](https://www.hearth.com/talk/data/attachments/256/256321-01aa87e782cd9dfa9d1d2ddf75efb7db.jpg?hash=nYFd2B2z1J)
