My wife an I installed a Big E pellet stove yesterday with horrible results. We connected the vent pipe (adaptor, cleanout tee, 4' vertical run, 90 degree elbow, thimble and end cap in that order) filled up the hopper, turn on the heater....and smoke eveywhere! We shut down the heater and sealed up all the joints on the vent pipe with heat tolerant caulking even the manufactured seems on all the fittings (yes, they were leaking too), and made sure all was tight.
We started up the heater and got mixed results on the quality of the flame and very little heat was coming through the exchanger. Manipulating the damper and controls did not change the quality of the flame or heat output. We shut down the unit for a couple of hours and retried starting it up. SMOKE, SMOKE, SMOKE! Smoke leaked from the unit in the following areas: through the door around the glass, through the seal of the door, from the heat exchanger tubes and from under the top frame of the pellet hopper. Upon further inspections of the unit, specifically the front door, I noticed a rope-type gasket between the metal frame and window extending from the lower left hand corner of the window extending up, over the top and then down the right hand side of the window-there was no gasket between the bottom of the window and metal frame-one of the sources of smoke seepage. I expected a certain amount of “smell” do to the newness of the unit but this was definitely smoke from smoldering pellets.
Does anyone have any idea what happened? Manufacturer's error, operator error (most likely)....
Thanks!
Thanks!
