Big e ignitor replacement
zrock
1,604
bc
I left enough room behind the stove during install that I'm sure I can get my arm in behind. Has anyone tried replacing blind?
Sent from my SM-G903W using Tapatalk
just a update save yourself a headach if your not pulling stove out to replace. Their is a set screw holding igniter in place that is easy to get at. Loosen set screw and replace igniter instead of removing to bolts that are in the holder. If your working from the side panel its a real PIA to get those bolts back in. Took me about 45 min to get the top bolt back in. Was just about ready to pull the stove.
