The only thing I envy is the 4 year old Oak.
I got out of Wood Stove for heat, but only had Pine in Easter Washington. Never burned Oak, but got some Red Fir and lots of What I called White Pine. Best stuff was Cedar. Lots of that available if I wanted to go where they log it and get scraps. Got some once. It burns very nice. Just a shame to burn cedar for firewood.
Cedar had lots of Rotton in the Center. They throw that away and burn in in Fall (slash pile). It's easy to get. I don't take trees unless GOD gives them to me. God's been too efficient. 2 Wind Storms in 2014, once in 100 years storms. One in 2015. I had lots of trees. Last snow storm took out 10 trees. Small ones that did not handle the load and snapped or fell over and uprooted. I bet good 1 Ton Pickup worth to give away this Summer after dry. Will de-limb and Buck up and stack and let it dry out and haul away to relative. I bet we had 80 trees down between 3 storms. I had guy log around house so no more smash thru roof (1 made hole). Might weed out some more for Safety. We got 75' Logging 3/4" wire with cat choker on it and hook. My work is cut out this spring with Fall/Winter cleanup. Alas can't burn it with Pellet Stove. Sure like not loading wood into stove. So easy the 40lb bags. https://www.westechrigging.com/logging-supplies.htmlThere are many trees I would never use for firewood, like Cedar. To me there are much better uses for most of wood people on this forum burn, especially stuff like oak. Coniferous trees grow faster and most aren't soight after for construction, furniture, etc. Our property is covered in spruce, with many dead standing trees. I forsee no need to cut live trees for firewood. However, we need to cut down several to have room for a garage, but I'm going to mill that stuff.
Cedar had lots of Rotton in the Center. They throw that away and burn in in Fall (slash pile). It's easy to get. I don't take trees unless GOD gives them to me. God's been too efficient. 2 Wind Storms in 2014, once in 100 years storms. One in 2015. I had lots of trees. Last snow storm took out 10 trees. Small ones that did not handle the load and snapped or fell over and uprooted. I bet good 1 Ton Pickup worth to give away this Summer after dry. Will delimb and Buckup and stack and let it dry out and haul away to relative. I bet we had 80 trees down between 3 storms. I had guy log around house so no more smash thru roof (1 made hole). Might weed out some more for Safety. We got 75' Logging 3/4" wire with cats tail on it and hook. My work is cut out this spring with Fall/Winter cleanup. Alas can't burn it with Pellet Stove. Sure like not loading wood into stove. So easy the 40lb bags.
Red oak 4 years young,one lone piece of cherry,one split 11 inches and about 30 lbs in weight.
There ain't nothing burns like a BK,when you find View attachment 236075 something better put me down for one. Just saying.
It's great,have plenty,tried to sell a couple cords only asked 300 cord ,people balked so i'm done. I'm having an Amish friend build a lean to on a concrete tpad 25x16,that oak will be put there this spring and last many years.Only top covered now,and 6 inches off ground ,not one bad piece.The only thing I envy is the 4 year old Oak.
Even after you take out the mill logs there is still lots of firewood. I almost never cut llivetrees for firewood. But I do cut up lots of tops left from logging on nearby properties. And I really don't bother with softwoods unless I have to cut it for some reason. Then I will burn it. Otherwise not enough BTUs to be worth my effort.There are many trees I would never use for firewood, like Cedar. To me there are much better uses for most of wood people on this forum burn, especially stuff like oak. Coniferous trees grow faster and most aren't soight after for construction, furniture, etc. Our property is covered in spruce, with many dead standing trees. I forsee no need to cut live trees for firewood. However, we need to cut down several to have room for a garage, but I'm going to mill that stuff.
Fir is used for 2xs, pine is used for a lot of things too. I got some fir once. It's not half bad, just as good if not better than maple.There are many trees I would never use for firewood, like Cedar. To me there are much better uses for most of wood people on this forum burn, especially stuff like oak. Coniferous trees grow faster and most aren't soight after for construction, furniture, etc. Our property is covered in spruce, with many dead standing trees. I forsee no need to cut live trees for firewood. However, we need to cut down several to have room for a garage, but I'm going to mill that stuff.
