We are intending to use our new wood insert as much as possible this winter, but our "main" heat source is a 24Kw Slant Fin electric boiler. Our 26x26 two storey home uses 6 cast iron rads on three loops, two rads in parallel on each loop, and with the electric boiler I have been able to run quite low water temps and still stay comfortable this fall.
In years past (last year we ran a 1950's American Standard Oil waster), we had problems with temperature overshoot, given high water temps needed by the oil boiler. So far, the overshoot isn't as bad this year,as I'm running the water at 110F, but I know I'll need to turn the aquastat up as the outside temps drop.
So here is the question - are there any good electric programmable thermostats that have a heat anticipator circuit? Most I come across have nothing more than a programmable cycle rate, and I haven't had any luck altering the cycle rate and avoiding the temp swings.
Given the cost of such a thermostat, am I better off spending the $500 or so on an Outdoor Reset Controller (like a Tekmar 260/261)?
While my boiler is electric, I imagine the issue is similar for those with wood boilers, as it is mostly a problem with the type of radiator and water temperature. Thanks in advance.
