Can anyone recommend a good website where I can look into purchasing some new pellet stove venting? I know there are many quality brands, but what is a good, affordable brand I should look into? Thanks in advance.
dac122 said:From personally installing Excel pipe on both my stoves after a fiasco with DuraVent PelletVent, and hearing the problems with other pipe, I would recommend you go with Excel pipe. If you are not sure personally inspect their pipe at a dealer along with the DuraVent products. I am sure you will like the quality and the thick replaceable seal on the Excel.
Though it is expensive pipe you get a great warranty and can tap your dealer for installation advice.
richkorn said:dac122 said:From personally installing Excel pipe on both my stoves after a fiasco with DuraVent PelletVent, and hearing the problems with other pipe, I would recommend you go with Excel pipe. If you are not sure personally inspect their pipe at a dealer along with the DuraVent products. I am sure you will like the quality and the thick replaceable seal on the Excel.
How much more expensive is the Excel Pellet than the Pellet-Vent Pro? Assuming a 4" PVP T is about $75.
dac122 said:richkorn said:dac122 said:From personally installing Excel pipe on both my stoves after a fiasco with DuraVent PelletVent, and hearing the problems with other pipe, I would recommend you go with Excel pipe. If you are not sure personally inspect their pipe at a dealer along with the DuraVent products. I am sure you will like the quality and the thick replaceable seal on the Excel.
When I had to rip out my Duravent PelletVent, I compared 3" and 4" PVP and Excel. The price difference was very close. After checking out the PVP at a local dealer I wasn't that impressed with the product, and since I was familiar with the Excel I went that route.
