This isn't really stove related, unless the long term answer is picking up a second smaller insert, but here goes.
Our raised ranch/split level home has baseboard forced water heat. Last winter we had a new Buderus boiler installed, and re-piped the house to correct the mess the previous owner made of the heating system. We now have 3 zones, each isolated and run by it's own pump. Two zones are upstairs, and the third is downstairs in our finished basement.
Last year, I had no problem heating the entire upstairs with our insert, and rarely if ever needed to rely on the baseboard heat. Downstairs was another matter, as the baseboard heat is the only heat available, other than an oil filled space heater.
The main "play" room downstairs is about 12 x 25. It has baseboard heat along the long outside wall, which is about 3/4 below ground, and the thermostat in this room controls this zone, with it's own (isolated) loop of pipe.
My question is, if I want to maintain temps in this room around 60 when nobody is using it, and 70 when people are using it, is it more economical (that's code for "cheap") to try to heat this room with oil heat, or to use an oil-filled space heater?
The biggest problem I'm finding with heating the lower level, is that the insulation is not great. The basement has cinder block walls, and in most cases sheet rock covers a single layer of foam insulation. Also, part of the lower level leads into the garage, which come winter gets freezing, and the downstairs play room shares a short wall with the garage.
Any thoughts on the best way to heat the one play room?
Thanks,
Sean
Thanks,
Sean
