Adios Pantalones said:Normal firebrick is easy to cut with a "masonry" blade on a skil saw. Soak it for a minute first- helps with dust.
A wetsaw can also be used.
A cold chisel can be used- score each corner, then each face, then a sharp strike- but ti will never be clean or accurate as a saw cut.
Believe me- I've cut a few fire bricks
(broken image removed)
raybonz said:You could try a small angle grinder with a masonry wheel to score the brick then break it from there..
Ray
