I would mix in your 4x4's as your burning your ash all season long! 1 or 2 4x4's with each reload of ash you do.
On another note: I used to get these same pieces of 4x4 and 4x6 and sometimes pallets were so huge and nice i would take off the large pieces and i used to run this stuff through my planner to use it for countless projects over the years! I take some pics of a few things i threw together with these hardwood freeebies and you guys will love it! Ive seen oak, mahogany, cherry all used for this stuff and it always felt like xmass time as ran this stuff through the planner
Yep, I use them for random other things too. Even though we don't just make Heat Exchangers, we also get a lot of the brass/copper/nickel etc... tube crates. So there's hardwood 1x6-8" pieces in there... Talk about nice wood...
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
A buddy of mine has his cathedral ceiling in his living room made all from the crates that he broke apart and ran through a planar
I'd split a few of the 4Xs at 45° & mix it in here & there to create some spacing.
Mix in some of the cord wood, ash, too.
How is it burning?
Is it putting out enough heat to keep the house warm?
You might be doing pretty good already
Pictures of a full load?
I used to do this actually, I would put the ash on the bottom so it'd light off quickly, and put the 4x4s on top (unsplit however). The 4x4s take a bit to start up if there's only coals left.
Great heat, usually 72-74 in here. Colder it is outside, stronger the draft... So warmer the stove runs... It's something I never actually thought about when I bought it. So if it's 40F outside, it's 72-74 inside if I burn on 1... If it's 15F outside, the stove burns hotter and it's still in the 72-74 range.
Sometimes it gets a little too warm if I leave it burn too long after reloading... The girl doesn't seem to mind. The cats love it.
My Dad has heated his shop for about 20 years with dunnage lumber like that. Most of the stuff he gets are softwood 2x4s though.
60 hours, as in ~2.5 DAYS on one load of wood?
Chinook 30 has a 2.75 cu/ft firebox, a bit smaller than a Princess.
Let's say filled it right full with 2.5 cu/ft, that is about 1/50th of a cord.
Ash is about 18,000,000 btu per cord. 1/50th is 360,000btus. The stove is listed at 80% efficient so that is 288,000 btus. Now not counting any time running it on high to get the wood going, the cat heated up, etc on 60hrs that only works out to about 4,800 btus per hour.... less than a 1500 watt heater.
I suppose in theory it could work out with a small well insulated house. At warm temps like 30* I usually just make one small fire a day.
You're right on the money boss. If you look up some of my older posts, I have all the math laid out comparing it to the other BK stoves, etc...
Keep in mind my house is 792sq/ft, and I just gutted it 2 years ago (finished last year actually... well, almost). Still have a lot of work to do yet but bulk of the job is done. I think the Chinook would've feel through the floor if I plopped it down without putting in new floor joists!
60 hours @ 20-30F... I burn up to about 40-45F... Those burns are a little bit longer.
The chimney temp usually falls to ~100 or so... But the cat is still active and no smoke.
Typically at 20-30F the chimney is ~190F. 18' Chimney.
I sweep monthly because of this... I use a soot eater so it takes nothing more than 10 minutes. My biggest complaint is that the chimney cap tends to get clogged up, but once you stick the soot eater all the way up there and beat it around the stove runs like a champ again
Sacrifice one season of burning the 4x4's. Store up as many as you can, cut them to length and log cabin stack them. Come back next season and start burning. They will burn much better for you.
This is my current plan. I figured I'd come here and ask for some advice to figure out the best way to split them or leave them whole.
Pictures Pictures....
Typical Ash load... There's maple mixed in here and there.
Here's a small load of the 4x4s
Taking some home... I don't care much about the truck... It was free from the girl's dad, leaks coolant, and is about to fall apart anyway... So I'm just finishing it off.
I might put a flatbed and a plow on it next year... Make one up easy enough. I couldn't find a flag, so I sprayed some liquid Penetrant on a piece of cardboard and used some E70s-6 wire to attach it... There's cops EVERYWHERE where I work, so I just wanted to make sure. It blew off about 2/3 of the way home anyway.
I got tired of my wood getting wet in the rain/snow... So I decided to use scrap wood and make a little enclosure. It looks like hell, but works like a charm. The house is getting sided in the spring, so I don't care too much. It makes my life easier for now and was fun to build. There's 3 more rows added on to there since then... (going left/right). I stack the ash on the other side behind where I was standing at the time
Ash when it was delivered... 1 dry cord, $330
I burn the leftover 4x4 pieces on weekends when I have time to tend to the fire more than once a day. They're the little scraps that weren't long enough when I cut down the full length boards. Sometimes they don't burn fully through the night, like last night... I had to burn the stove for a little bit to warm the place up. She doesn't seem to mind
Nice clean glass still, even though I rarely ever burn hot. The only time I've cleaned the glass this year was for thanksgiving when my parents came over for dinner.
Digging through my pictures I found this... With a random 2x4 I had laying around.
This is about as hot as the stove ever gets. It does have a convection deck so it's not the true stove top temp... But I've got it to 550
once. Usually 500-525 seems to be the max.
and since I'm putting up pictures, here's my latest addition... a random buddy I found when I was going outside to cut some floor. Those aren't spots on my camera... lots of burrs, fleas and dirt.
He stayed outside my door for about a week trying to run in every chance he got...
Girlfriend loves how friendly he is, and nobody else in the area claimed him so he went to the vet...
He was 6lbs and bony as all heck... So 3 months later he still wasn't gaining weight... So back he goes, only to find out he lost another pound!... $300 later, we find out he had a bad bladder infection and he's hyperthyroid. So he's starting to gain some weight now.
I don't know what happened to his ears though... Either frostbite or bad sunburn... His fur still hasn't grown back on them.
Part of the cat family now....
Sorry for all the pictures, I go overboard sometimes!
