I found a few older threads but wasn't sure if anything changed. I currently have an older second hand VC encore that is limping through its final season with us. I have enjoyed the heat it provides, but this stove has always been particularly finicky (my dad works with them much more and said this particular unit was always that way).
I have an 1800 SF home and the encore has done pretty well, though I could get one with a bit higher or lower output as my house has multiple zones and I also have propane heat. Unfortunately I can't adjust to top venting and my height it limited unless I tear apart the fireplace, removing its current bulky face that limits some of my clearances. I have about 28" of clearance height wise and 23" front to back.
Ideally I would like a stove that burns a bit longer without being babysat as we have only been able to max out this one at about 6 hours, I have also seen on here that VC tends to need more frequent maintenance than other stoves. I looked online and see Woodstock is an option but a bit big, it does otherwise look like it could fit the bill though. Other suggestions? I wish blaze king did rear venting but looks like that's not to be
