I have searched for days online and spoken with two local dealers at length, trying to discover the best new stove choice for my existing chimney if I do *not* want to install 6" stainless steel liner. The dealers opinions (and/or lack thereof) vary so considerably that I am not confident yet when considering spending $2000 on a new stove. I am now here hoping to glean any insight from those who may have experience venting into a chimney instead of perfectly sized 6" SS pipe.
Some background details:
20 year old Basement entry on slab traditional framed home - R40 in ceiling and R20 walls - double glazed windows.
1200 sq ft main floor down where the wood burner and cold air intake is.
1250 sq ft upstairs vaulted ceiling
Straight up appx 30' central chimney built to code with 6"X10" tile flue
I've had a 20+ year old mid size air tight stove (Cascade Triumph running well but with short burn times and too much pollution) Stove enters chimney via single wall pipe into masonry thimble.
With the vaulted ceilings upstairs, approximately 20' of the 30' chimney is inside the home with the remainder in the attic and above the roof line. Each year I get some glazing in the top 10' of the chimney and I clean and inspect it thoroughly myself and have done so for over 10 years. The wood stove has been backup to hot water Nat Gas hydronic heating system (separate vent in same chimney) in floor down and in registers up, but that is on the verge of changing modestly.
I am looking to buy a new, sturdy EPA stove to A) cut down on pollution B) provide longer burn times and more even heat using less fuel and C) the new stove (or the old stove if I can't find a suitable new stove that will draft well) will also have a custom *external* water jacket placed on it's rear or side end, that will pre-heat my hydronic heating water (yes, it will be professionally done with pressure relief valves, extra storage tank, backup circ pump and all essential overflow protections. It will be external, not internal in the firebox so it should not radically affect the burning)
Drafting has never been an issue with my chimney and my old faithful smallish stove, as long as I use well seasoned wood and get it and the chimney warm before dampening it down, but I 'hear' the new stoves may prove difficult on anything other than pure 6" pipe ad not even sure I can get 6" pipe down my flue if I needed to.
So far I like the two local large size stove choices of Regency 3100 or the Pacific Energy Summit, but not even the dealers are much help with info on their performance on a 6"x10" flue, saying only that if I encountered problems, I would more than likely have to go with a 5 1/2 inch flue liner if things don't work out, but then that could also be an issue as it might be too small - {this is where I started rolling my eyes}!
Does anyone here have any experience running either of these stoves or any new EPA stove for that matter, on an existing 6"X10" vertical chimney?
Is a larger EPA stove better for a larger flue size and higher chimney? I don't want to be roasted out of the house but longer burn time and not having to add wood every 3 hours like my old beater stove, is important to me.
Anyone have experience with EPA stoves on regular chimney flues? Can they work well? Can you dampen them down and still get a good clean burn?
Thanks very much in advance for any and all feedback![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
