If you could vent your wood stove either straight out the back to the chimney or up first (several feet) and then out the back wall, which is the preferred or better method?
Thanks, John
Thanks, John
BeGreen said:I'd go in and ask for a code review before submitting for the permit. The room will need to be large. You will probably be required to provide the room cubic footage and proven air exchange far exceeds the stove air consumption. (An OAK may help getting this variance.) The return air grille probably won't make a difference except that it will need to be at least 10ft away from the stove. An open entryway, no door, may help more. Note that many stove manuals explicitly say their stove is not to be installed in a sleeping area and depending on the code reviewer, that may trump all.
Seems like a lot of hassle and expense for the rare fire there. Maybe just put a flat screen in a nice brick veneer surround and play a fireplace dvd? In the summer you can put on polar bears or an aquarium.
