Best 3" Duravent compatible horizontal vent end?
tbear853
Well, so far the old stove has been great since the most recent incidence of excessive feeding of pellets, that turn on the feed rate knob seems to have cured that.
I used to have my outside vent (3" Duravent) extend out from the stove on a 36" pipe section to a clean out tee outside, then straight up through my carport roof eve, up through another brace, to about 2 feet above the steep house roof. I had a vent cap on it. It was all about 15 feet from the tee straight up. When the roof was shingles, which I put on our new log home we built in 1990-91, I was able to walk / work on it.
In 2017, we had a contractor re-roof with metal, and I changed the pellet flue and eliminated the hole. Since then it went up 5 feet to a 90 elbow, and a Duravent tapered type horizontal end on it, pointing outward from under the 2 foot overhang. The nearby wall is metal as well. I've noticed that if it gets real windy, we can smell faint smoke.
Today, I added 6 feet of pelvent to carry that exit further along that carport wall, away from living portion of the house. Reused same tapered end, aimed outwards and slightly down, thinking any smoke blown back towards the house by a gust will have 6 more feet to dissipate. No log home is totally sealed.
Wondering if there are any better terminus ends, or if this is the best? Guessing we'll see tomorrow as wind is promised, but still curious if anyone has a suggestion. As it sits, total flue is 14+ feet including stove adapter, pipe through wall, tee outside, 5 feet straight up, elbow, 6 feet horizontal, end. I purposefully included slight rise in the horizontal run, I added it as the stove run. No water, no snow gets on the pipe.
  • [Hearth.com] Best 3" Duravent compatible horizontal vent end?
Is a concern I share, Many years ago when first built, the carport there was open, just a rail. There was no tee, just a long horizontal flue to the end out past the rail, I guess was over 20 feet. I then just used a cap I later discovered was for vertical pipe, but it kept wind out.
When warmer weather arrives, like spring, I might run the straight pipe straight up and brace to the wall and roof edge, but I'd hate to go through the roof like before ....which means tilting it outwards to clear the carport roof edge there, then continue upward at a 17 degree (from 90) angle and next to the porch roof. I would then use a vent cap for vertical pipe, but it would be tilted to 17 degrees too. As it is now, I'd have to buy the cap, and likely a new adjustable elbow.
A 17 degree turn is not as restrictive as a pair of 90s to simply step out from under the eave. Just playing with pics.
ummmm... First issue is you need a bit of extension up thier to point it away from the house. With it like that the wind comes off the roof and creates a slight vortex under the over hang, also i think the way you have it is against just about every building code. As much as you hate to do it put it back through the roof that is just a really bad spot to come out of the house with it going through the roof in that location you do not have to worry about any leaks into the home.
Reactions: Ssyko and tbear853
Thank You Sir for posting your thoughts. It does help.
It's actually not a code violation here and had it been beside a living portion of home, I would have done otherwise 33 years ago (to escape a living space window), and that wall is ribbed steel roofing with ribs that space the pipe out a minimum 3/4" away from the flat portions between the ribs. The nearest living space window near as high as the flue exit is a good 25 or more feet away. I started using this flue end a couple years ago on just the elbow seen, I just yesterday extended it 6 feet horizontaly. It is still pointed downward and outwards from the carport wall pretty much like in this picture, but it is overshadowed by the roof overhang and is about 13-14 feet above a rock covered flower area at the bottom of the carport masonry foundation wall which is below the steel. The windows are just for letting in some day light in the carport, the other end of the carport is wide open to the driveway with no doors.
The pipe exiting the wall is a 3 foot long pellet vent pipe through double wall thimble for pellet venting, with a cold air inlet beside it ... and exits behind my stove on a stone hearth which has near a foot of near straight pellet stove adapter pipe now. When first installed, the carport was open with just a railing. and roof. I added the carport walls later. I've replaced all the piping in the last few years.
As I'm typing this It occurs to me ... I could put a "45 turn on the new 6 feet of pipes" end ... then put this same tapered end back on (it has a up to "45" of its own) that 45 end .... that which would both:
A) bring the opening out to the edge of the overhang and
B), point such gasses 90 degrees out from the eave.
It does increase velocity of exhaust gasses exiting the flue as I noticed yesterday as I did this latest 6 feet of extension bare handed on the ladder "testing" the effect of the cone. Flue was comfortably warm, exhaust gasses still very warm, stove was at low setting but running nice.
I thought was gonna be windy today, but I see that actually the wind is due here tomorrow ... that will be the test I guess. Light snow now.
I took this from porch end, and yes, I have birds. I'll clean that mess in warmer weather.;)
Wind is kicking up, but no faint smoke smells. I'm thinking the extra 6 feet did the trick. 👍
Never thought it was window related, believe is the fact that to end of the house is closest to the direction from where our winds come, and strong gusts would blow the exhaust across the car port roof towards the log gable of the house. Log gables are cut logs stacked, sealed with a spline, foam, and a log sealant caulk all, but there are slight gaps like between log ends and the roof panels. Very few maybe, we put a lot of effort there, but there are some leaks. The hope was that the extra distance would lead to greater dispersion before the exhaust reached that wall.
After twice suffering power outages and seeing how the stove smoke is on a sudden chop .... I'm gonna remove the 6 feet horizontal, back to the 90 and just put the horizontal cap back to get through the winter, it did not smoke so bad on a sudden chop of power back when I had it like that.
The stove is running better, but that has more to do with the feed adjustment and a known good thermocouple. I'll just put the two removed sections on a rack, after I compare outlet to where it would exhaust with that 5 foot vertical piece.
Come warmer weather, I'll revisit my options, like punching through the roof metal and pushing pipe up through to that upper holder still there.
Gonna also look at UPS alternatives this afternoon.
Termination design is likely not contributing to your concern. Earlier post mentioned “code violation “. Not so much a code violation but venting layout could certainly be contrary to stove manufacturer’s certified installation instructions.
Best to review before changing configuration. May require increasing to larger 4” pipe for longer run.
Tee and 90 elbow both add flow resistance. Each is typically treated as 5 feet of equivalent length. With most stoves equipped with 3” outlet, need to increase to 4” pipe once you pass 15 feet of equivalent vent length.
Instructions will also require minimum projection length from outside wall, inside/outside corners, and clearance below soffit.
Today climbed up, removed the 6 feet horizontal section. Kept the 90* and terminus piece. As soon as I find a vertical terminus that will go through that bracket that is still up there , I'll punch through and go straight up. I'll reuse the near new 6 feet of pipe I just took down, it's enough to put the terminus a couple feet above the upper roofs edge. Old picture below before roof, etc. That was 14 feet vertical, the stove had great draft too.
In a big snowstorm now and am pleased that I went back. I did turn the top 90* with tapered end pointing more outwards near perpendicular to the wall, not so near parallel with the wall as was. We neither one have noticed any smoke smells like we thought a while back. Did just push button on the UPS to see what starts to happen. A short, brief test as if power went out. Huge reduction in smoke in the stove due to the sudden loss of the draft fan, and the fire acted as if there was still a draft of some sort, though maybe reduced.
In short, obviously a cleaner shut down if a sudden power loss.
In the USA installing a listed product in a way which doesn't comply with manufacturers instructions is a code violation
It's in compliance .... and it's running well.
I didn't get to punch through that carport roof yet, but today (11-29-2025) I did a good clean on the stove, and fired it up first time since last winter, and it's running really nice right now. I'm still thinking punching straight up is the best ticket .... but my only issue with punching through and up is I'd then have to go up on the roof to terminate it after going through that still existing upper brace which is a welded steel loop that is a maybe quarter inch bigger that pellet vent, but no terminations for a vertical pipe will fit through from below. Someone would need to get on the roof and put it on last, and I can't now like I used to could.
Right now that horizontal vent is about 90 degrees to the prevailing winds here, so the wind is not blowing into it, but past it. Again, the vent is above and away from windows of the house, and even the carport itself.
