I'm pretty close to purchasing the Hearthstone Bennington. They say it has an exclusive all double wall construction cast iron frame. What is that about? I'm not sure if this is a good thing or not. Will it take longer for the outside surface to heat up? Are there any pros or cons with this design? Hearthstone really doesn't give much info. about it. All they say is " With an exclusive double-wall cast iron frame and built-in rear heat shield, the Bennington’s huge firebox actually serves as a convection chamber that allows air to circulate within, and then return, thoroughly warmed, into the room." Is this a gimmick, or what? Does it affect burn times or anything? I looked through the manual online and didn't find any other info. on this double cast business.
