round cast iron ash plug - this is in.
Do i only remove this when sweeping ashes through the hole into the firebox underneath on the pedestal?
aside from this plug, the bottom (sides and inside ceiling) are refractory bricks.
but the manual mentions raking the coals on the bottom.
can anyone elaborate.
Does anyone have a basic picture diagram of airflow within the pedestal/stove. or youtube video.
Trying to grasp the EXACT circulation.
Especially in regard to the AIR INTAKE CONTROL and SECONDARY AIR TUBES (on the top of the inside)
I'm failing to correctly understand where the air is entering and leaving the main chamber
I want to easily verify the air intake control is properly working.
Stove and manual are found here.
www.drolet.ca
thank you kindly
High Efficiency Wood Stove | Escape 1500
The Escape 1500 is EPA certified at 1.26 g/h - 65,000 BTU/h to heat up to 1800 ft² - 6h max burn time -18" logs - Pedestal model - Made in Canada.
![www.drolet.ca](/talk/proxy.php?image=https%3A%2F%2Fwww.drolet.ca%2Ffavicon-32x32.png%3Fv%3Df55241b4cbcd9eed632871c0167cc17a&hash=e856dbced5a0c7ae9e91e147ad413d0b&return_error=1)
thank you kindly
