Hello everyone,
First time poster, about to get a wood stove (thinking about VC Encore Flexburn, but that's not why I write) and want to vent it out of an existing fireplace. The fireplace had a 1" think slate slab that sat on several layers of mud bed, mortar, and piled rocks/concrete. I need to extend out the hearth for the wood stove and want the new hearth level with the existing brick of the fireplace bottom. I got a new slate piece that is 60" x 32" x 0.5".
I cut out the existing hardwood floor to the new size of the hearth, pulled up the (cracked) slate and the top layer of mud deck, and then another ~1" layer of some kind of mortar bed. I'm left with (from the fireplace and moving out) a pile of rocks held together with concrete that sit on earth. Then a gap (where the subfloor was), then half a width of log floor beam before the hardwood starts up again.
My plan was to fill in the big open space with layers of rock and high strength concrete to make level with the existing concrete pile. Then pour the high strength concrete over everything with a remesh embed to about 3" shy of the fireplace bottom. Then level off with a cement self leveler (about 1" thick). Then layer 3 layers of 0.5" durock on top of the cement for r-value. Then thin-set mortar the slate to the durock.
However, I ran into the issue of not knowing how to attach the durock to the newly poured cement level (could I just embed it in there, use concrete fasteners?). I know you should only attach to wood or metal. Any other way to get the r-value I need (1.06)? I don't think the concrete by itself would cut it.
Thanks for any input!
![Beefing Up & Expanding Hearth for Wood Stove Beefing Up & Expanding Hearth for Wood Stove](https://www.hearth.com/talk/data/attachments/237/237763-1fbd05b6f336e297d1fcd3e8f61d5638.jpg)
![Beefing Up & Expanding Hearth for Wood Stove Beefing Up & Expanding Hearth for Wood Stove](https://www.hearth.com/talk/data/attachments/237/237762-27cfbf97709b434834eb5a157a56909e.jpg)
