Hey! We built a house and moved in February 2010. We have a gas fireplace that is not intended to heat -- basically just for aesthetics. While it does produce a bit of heat, it does its job of being "pretty" very well.
There are seven of humans and four dogs -- we can generate a fair amount of dust. Herein lies the problem....
Many times, the fireplace will not ignite. The pilot light is on and burning beautifully but the flame won't expand out and dance among the logs (I don't know the technical words). I have usually removed the front glass and vacuumed dust out and received flames for a while -- then nothing again.
Last night, by sheer luck, I found the problem. There are two wires that are coming from the very top exterior of the insert (I have to removed the top decorative vent and the glass cover to see them). From what I can see, they go from the top of the right side of the fireplace (between firebox and brick wall) and travel down to under the fireplace. I jiggled those last night and suddenly -- FIRE! Today, no fire. Jiggled wires -- FIRE!
What is wrong? How do I fix it? Is my house going to burn down? I've attached three pics to (hopefully) make more sense of my rambling post.
It does have a wall switch that is supposed to make flames. First picture is underneath of firebox. Second picture is looking down at top wires, between firebox and house wall. Third picture is make and model.
THANK YOU SO MUCH for any help in advance![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
![Basic Problem with Gas Insert Basic Problem with Gas Insert](https://www.hearth.com/talk/data/attachments/117/117510-68872b958b6d2b9bca3e99d04cc85e42.jpg)
![Basic Problem with Gas Insert Basic Problem with Gas Insert](https://www.hearth.com/talk/data/attachments/117/117508-a05abf0641824ad737de25c300442620.jpg)
![Basic Problem with Gas Insert Basic Problem with Gas Insert](https://www.hearth.com/talk/data/attachments/117/117509-970fb97825e91693ba6ece5066362876.jpg)
