I have a JOTUL F 400 that will be going into the corner once the noncombustible walls are put together. We will be running through a wall and through the first floor to attach to a pre existing chimney, with appropriate clearances and shielding.
We opted to build a lower ceiling above the stove to divert the heat from the ventilation pvc piping for the central air and the sewage line from a bathroom.
Will the heat generated from the stove still be too high for the pvc pips and electric wires running along the joists? Should we look into pipe insulation and or additional heat shielding for these locations? I attached some photos of the pipes and wires in question.
Thank you for the help,
![Basement Wood Stove - Unfinished Ceiling Basement Wood Stove - Unfinished Ceiling](https://www.hearth.com/talk/data/attachments/300/300172-42c9c706830f36efdd263b3ad72f8363.jpg)
![Basement Wood Stove - Unfinished Ceiling Basement Wood Stove - Unfinished Ceiling](https://www.hearth.com/talk/data/attachments/300/300171-a180ed620f8c1f6ed2a6cbef5dc79335.jpg)
