- Oct 3, 2007
- 1,539
On the opposite side of the basement from where my ESW furnace lives was a finished area that was some sort of office with a closet. The previous owner of the house did a good job on framing the finished walls with a vapor barrier and fiberglass insulation, but the drywall work was so-so and there was never any carpeting installed. We decided to convert the area into a combination office and family room with a built in entertainment center. Here's what it looked like after I began tearing out the drywall around the closet enclosure. Part of the enclosure also hid the sump pump I decided to keep the basic framing and refined it. The sump pump will now be hidden by a built in bookshelf which will pull out of the wall if access to the pump is needed. Before everything is finished the pump will also get a battery backup.
Here is the same area after removing all of the demoed material and framing the entertainment center:
I need to run electrical outlets in the wall where the TV (I deliberately sized for a 52" wall mount
) will mount along with in the cabinets which will go below the TV to hide the cable boxes, etc... Other plans include wainscoting, a kegerator, a small bar, New Jersey Devils and New York Giants memorabilia, and some comfy couches.
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
