Hey everyone here’s the issue I’m dealing with. I had a contractor install insulation in my walkout basement walls above grade. They first picture framed the stud cavities with spray foam and then put in the blow in blanket system with fiberglass. The issue I’m wondering about is I’ve had issues in the past with condensation forming on these walls behind unfaced batts in the winter. So since this is already done, is there a way I can not have condensation form in the winter behind this blow in blanket system? I’m just guessing it might happen since fiberglass is air permeable....I thought about using the membrain product from certainteed...Any suggestions would be great, thanks!
![Basement Insulation Basement Insulation](https://www.hearth.com/talk/data/attachments/261/261578-5d66bf6970b0981010d6fb1784d32bb1.jpg)
