Basement install new construction
Claytronic
1
PA
Hello everyone. Rather new and need some help with my new construction home. It is a 1560 sq ft ranch and I was planning on putting a blaze king bx24 in the basement. The builder built a wood chase on the gable end of the home which is supported by superior wall.
I was planning on using a duraplus through the wall kit and duraplus 36" lengths.
My questions are:
where would I put a clean out door since the cleanout t will be below grade? I am assuming inside the basement - best practice?
Do I need to support the 18 plus feet of duraplus as it is going up the chase or does it lock in securely to each section and support by the t support?
Thanks for any help
The chimney tee needs to be outside in order to make the 90º turn up. Is the basement insulated and a finished space? If so, the ideal location would be central, near an open stairwell to upstairs. Otherwise it can be hard to heat the main floor from the basement. Would it be possible to locate the chimney up through the house or would it be possible to put the stove on the main floor instead?
