I have a basement installed Blaze King Ultra. Looking for ideas to equalize temps between basement and 1st story. 78 to 80 in basement and 71 upstairs
Please let us know how this works, our install is supposed to be within the next two weeks and we are going to have the same issue potentially.I'm definitely going to watch this thread - my install is next month, but I'm certain I'm going to have this problem. @Indianawood is your basement finished, or unfinished?
Many members on here have made good suggestions which usually involve cutting floor registers to facilitate cold air sinking back to the basement. As far as ducting, I have an idea I am going to try, which I will definitely give feedback on in the future. Rather than cutting a floor register and hoping it's big enough, and the air moves on its own. I'm going to buy some 8" flex duct and an inline 8" duct fan, because of the way my basement is finished and laid out, I am going to put one floor register in a cold corner of the first floor, and basically duct it down into a corner of the basement, pushing cold air down. Hopefully giving warm air a smooth flow up the basement stairs, and getting a nice thermal loop going.
The duct fan I bought pushes 420 CFMs, so with basic math, I calculate it should be able to fully circulate all of my first floor air every 15 minutes or so. I don't see how this wouldn't work well.
Not sure what your basement layout is, but just food for thought.
Just to make sure I understand you correctly, because I have not tried. That option, are you moving warm air up or you blowing cold air down into the basement and then letting the doorways and maybe a stairway filter the warm air up?Im doing the exact same thing. I cut a register vent hole in the floor and deducted it to a good inline duct fan. Works great dropped the bastment temps down about 4F. I have it run 24/7/365 now. It helps keep the basement more even in the summer too.
I use one like this one blowing the cooler air from the main floor into the basement and that allows more of the warm air to go up the stairs.
VENTS-US VENTS 225 CFM Power 6 in. Mixed Flow In-Line Duct Fan TT 150 - The Home Depot
VENTS Turbo Tube, TT 150 Mixed Flow Inline Fan is ideal solution for multi-purpose use in residential and commercial ventilation. TT 150 combines the features and benefits of axial and centrifugal fans.www.homedepot.com
What do you think the temperature difference is between one side and the other (incoming air temp of your unit vs destination room air temp).Im doing the exact same thing. I cut a register vent hole in the floor and deducted it to a good inline duct fan. Works great dropped the bastment temps down about 4F. I have it run 24/7/365 now. It helps keep the basement more even in the summer too.
This is great to hear, because it's exactly what i'm planning. I think the layout of my house is going to work really well with this setup, forcing the air to flow through my 1st floor on its way to the duct inlet. What size floor register, and what size duct do you have?Im doing the exact same thing. I cut a register vent hole in the floor and deducted it to a good inline duct fan. Works great dropped the bastment temps down about 4F. I have it run 24/7/365 now. It helps keep the basement more even in the summer too.
Perfect thank you, thanks for the pics. That's almost exactly what I'm picturing. I have a small closet that houses the water tank, similar to you, unfinished basement space, I plan to run it in there and vent it out as well.Think mine is 8 inch.
View attachment 268459 View attachment 268460
BTW thats the room we call the monster room. it has my service panels and network servers and crap in there. lol
