I've just installed a Blaze King Princess Insert into my 1st floor fireplace & was thinking of a way to circulate the cold air from my basement to the stove by using a 4" cone/squirrel cage fan at the basement ash pit cleanout door & ducting 4" flex up thru the ash dump door at the floor of the inner hearth, terminating w/ a 90* elbow pointing at the back side of the insert.
The air should escape from around the shroud, and create a loop w/ the stove room air being drawn downstairs as it's adjacent to the stairwell.
I have a block off plate at the damper & packed w/ Roxul solid so no air will go up the chimney.
The concern I have is the hot water heater (HWH) & furnace are next to the ash pit cleanout door in the basement utility closet, & wonder if I will create a negative pressure in the utility closet drawing the fumes from either appliance thru the fan. The furnace is direct vented to the exterior w/ PVC, but the HWH has an air gap between it and the draft hood that is ducted into an adjacent chimney flue so the exhaust from the HWH might be pulled into the utility room from the fan.
Do you think this is a cause for concern?
