barometric damper?
if you have more draft than the boiler spec calls for, then yes it would be a good choice.
How the heck do I know that? Excuse my ignorance. I assume I need some sort of draft-measuring device?
At the risk of hijacking the thread a little, do units with closed-loop stack temperature control, e.g., Fröling, require a barometric damper?
That digital meter has a 40" range. Recommended drafts for boilers are about 1/20". I don't think you could count on the accuracy of the meter to give you a measurement that would mean anything useful.
Chimney draft meters are pretty sensitive devices. They measure too narrow a range to be useful for much else.
Reactions: Owen1508
I use this one.
It's cheap enough so you can just mount it permanently near the boiler(s). Even 3" is high though; I suppose that's the lowest range of the Dwyers?
That's the same one I have & was trying to recommend. Mine has been permanently mounted since September 2012. Simple & reliable, and seems to be quite accurate too. Took just a little bit of fiddling, and a little bit of spilled red stuff, to get it zeroed the first time but I haven't touched it since. When burning in the winter I'm pretty steady right at 0.1".
Does the Mark II 25 come with detailed instructions regarding where to mount, where to measure, etc? Do most of you have your dampers below your T like taxidermist? For whatever reason I envisioned installing mine above my T, between my T and the stove pipe.
My manometer probe is about 6" from the back of my boiler, then my barometric damper is a couple feet downstream of that, followed right away by a cleanout T that sends things up out my chimney - except for a bit of ash that doesn't make it up & out & therefore settles in the bottom of the cleanout.
The draft probe needs to go in between the baro and the stove. Preferably in the middle of a straight run of pipe
I only put it there because it was a after thought and i would hav had to buy more high $$$ pipe to make it work. That being said it works great where it is and it stays very clean.
