In the recent other thread about putting examples of gasifiers on YouTube, when I looked at Hansson's from Scandanavia, I noticed he had a second video, and it appears to depict a chimney draft regulator/ barometric damper installed in connection with his gasifier.
See:
http://www.youtube.com/watch?v=cEycuK_9Zb4
From prior projects I have done, it's always been my understanding that USA codes and practices say that a barometric stack damper is a total no-no with any solid fuel appliance.
I happen to live in the relative boonies where "the only mandatory code is my own judgment" so I do not have any official worries, although I do like to design and construct carefully and conservatively, especially when it comes to anything relating to fire or exhaust.
But Hansson's video has me curious. I know that the basic goal of a barometric damper is to avoid situations where there's too much draft "pull" from the chimney in a way that would draw the combustion through the heat exchangers more rapidly than the heat can be efficiently extracted. It makes sense to me that this could be advantageous with a gasifier just like on an oil burner.
Any thoughts on whether it's sensible to consider a barometric stack draft control on a gasifier?
While I'm asking about such things, I also have been wondering about pros and cons of rigging an outdoor combustion air supply to feed the blower fan on a gasifier. I know that many of the more modern high efficiency fossil-fueled heating devices are designed and installed this way, so that combustion air can be obtained without creating negative pressure in the conditioned space, wich would then draw in drafts of cold air elsewhere. As far as I know, none of the gasifiers are built with this "outside air" included, but from looking at a couple of them, it doesn't look like it'd be rocket science to adapt or fabricate an arrangement by which the blower could draw from a pipe to the outdoors, rather than drawing from the "room" around the unit. This crossed my mind in connection with the stack damper, as my understanding is that "outside air" arrangements also decrease the variations in chimney draft (because both intake and exhaust are coming from outdoors)
Thanks all for any input
Trevor
See:
Trevor
