as I keep moving forward with planning and construction of my system, I'm going to need some moderately long, moderately large diameter lines, around 1.25 to 1.5 inch, between the primary loop and the 1200 gallon tank, and then also between the primary loop and the water-air HX
to me, big iron in long lengths is klutzy to work with and support, especially through somwhat crowded existing low-ceiing old farmhouse basements like mine.
copper in these quantities is going to be scary on cost.
so, I keep coming back to PEX,
but I am finding a relative lack of fittings of any sort in the bigger sizes, and an even bigger lack of fittings that don't either cost an arm and a leg or require some unusually exotic tool that itself costs several arms and legs.
I think I have heard of OWB folks using barb-fittings, like you'd use with black poly pipe, and then hose clamps, with pex. But of course, OWBs generally run no pressure other than the weight of the water. the hose clamps wouldn't help me sleep well at the more significant pressures of a regular domestic system.
but then I got to thinking of a tool that I already own from other projects and that can clamp things tighter and more uniformly than regular worm-screw hose clamps:
http://www.clamptitetools.com/
I can use stainless wire with this tool, and could run a bunch of wire bands around the pex, quite tight, after a barb fitting is inside
I'd appreciate feedback on whether I may be onto something, or whether this is a direction best avoided.
thanks, as always, for all the great experience and ingenuity and support 'round here
